Brake Pedal Height
  • Hallo
    I have an issue with my brake pedal, it sits a lot higher than I think it should. (Single Circuit)
    The braking performance is fine once it reaches the end of its very long free play (4cm-5), but on release the pedal returns back to its very high position.
    Is there a way to prevent the pedal from returning so high?
    It appears that its only the spring that is causing it to return so high, If I remove the spring, the pedal sits around the correct height.
    [Blocked Image: http://i.imgur.com/f72Te47.jpg]
    Where the freeplay ends:
    [Blocked Image: http://i.imgur.com/2etJtNc.png]
    Apologies for this been in English
    Regards
    Andrew
  • You've got the bolts of the clutch pedal keeps turning. That's the wrong way around it. The long side of the bolt serves as a stop.
  • It seems so obvious once you've pointed it out.
    Thank you very much
    Regards
    Andrew.
